silvermachine Posted February 21, 2005 Report Share Posted February 21, 2005 I need to move the libray location in Sonic Stage but can't work out how to do it. Under "options" I've changed the location but this appears to be only for new stuff, nothing that's already on my machine.Is it possible to sort this?Cheers Quote Link to comment Share on other sites More sharing options...
dex Otaku Posted February 21, 2005 Report Share Posted February 21, 2005 As this was the first thing I did after installing SS, I can only assume that the following might be your solution:* back up your SS library to a folder on your hard disc using SS's backup tool* Either remove SS or just empty your library by deleting its contents* Restore the backupNo guarantees that this will work. Quote Link to comment Share on other sites More sharing options...
silvermachine Posted February 21, 2005 Author Report Share Posted February 21, 2005 dex Otaku said: As this was the first thing I did after installing SS, I can only assume that the following might be your solution:* back up your SS library to a folder on your hard disc using SS's backup tool* Either remove SS or just empty your library by deleting its contents* Restore the backupNo guarantees that this will work.←Cheers, I'll give it a try! Quote Link to comment Share on other sites More sharing options...
dex Otaku Posted February 21, 2005 Report Share Posted February 21, 2005 silvermachine said: Cheers, I'll give it a try!←Before you do - I'll go back on the recommendation to possibly remove SS. Just do the backup, erase your library [knowing you now have it backed up], then restore it with the new location active. Quote Link to comment Share on other sites More sharing options...
