New to vaio pocket need advice
whistler_
Had my pocket vaio a few weeks now and love it especially with the new firmware. However,1) how do i get the lyrics function to work and 2) is it usual for the battery to be totally dumped and need recharging after 3/4 days of being turned off,3) is atract3+ 256 kb/s the best quality to record. thanks for any info. You Guys really know your stuff
2 answers to this question
1.) Lyrics only work for ATRAC files. You can right click a song, go to properties and there should be a lyrics tab where you can type or paste in the lyrics for that song. Then transfer the song to the unit and during playback you should be able to view them via the lyrics icon.
2.) Yes. The unit never fully shuts off even when off. This is why it has such a short startup time. In the off position, the battery will continue to drain and usually be drained within a week or so. Best to keep it on the charger during idle time.
3.) ATRAC3+ 256kbps is arguably the best quality the unit can play, though if you prefer the sound of a higher bitrate mp3, that may sound even better. (VBR->320kbps).
