D-Wade Posted October 16, 2005 Report Share Posted October 16, 2005 whenever i transfer atrac to my psp it always freeze and will sayor when i manually drag mp3 to psp's music folder using copy and paste it will sayi tryed it on my dad's laptop it work when i manually drag the mp3 to psp's music folderplease help thanks Quote Link to comment Share on other sites More sharing options...
Ishiyoshi Posted October 16, 2005 Report Share Posted October 16, 2005 Welcome to ALC!You can certainly copy Mp3s into the "x:\PSP\MUSIC" folder. However, with ATRAC files, you will need to use SonicStage 3.2 to facilitate the transfer. In addition, ensure your PSP have at least firmware 2.0 installed to utilize ATRAC3plus tunes. Quote Link to comment Share on other sites More sharing options...
D-Wade Posted October 16, 2005 Author Report Share Posted October 16, 2005 i have psp 2.0 the memory stick 32mb that comes with psp but still wont work does it have to do with codec?and when i try to put mp3 to /PSP/MUSIC i get that errorand when i use 3.2 sonicstage i get the errorhow do i send it to my psp properly?it works on my dads laptop and my other comp Quote Link to comment Share on other sites More sharing options...
Ishiyoshi Posted October 16, 2005 Report Share Posted October 16, 2005 In that case, it appears that the root of the problem lies with the PC you employed. For starters, please state your system specs and we will try and help.*topic moved to "Software" section Quote Link to comment Share on other sites More sharing options...
D-Wade Posted October 17, 2005 Author Report Share Posted October 17, 2005 (edited) Processor Intel® Pentium® 4 CPU 2.53GHz Processor Speed 2.46 GHz Memory (RAM) 256 MB Operating System Microsoft Windows XP Home Edition Operating System Version 5.1.2600SystemMicrosoft Windows XPHome Edition Version 2002Service Pack 2Dell Computer CorporationDell DIMENSION DIM4550Intel®Pentium® 4 CPU 2.53GHz2.52 GHz, 256 MB of RAMis that enough? and where do i go to see the complete system specs?thanks Edited October 17, 2005 by D-Wade Quote Link to comment Share on other sites More sharing options...
Ishiyoshi Posted October 17, 2005 Report Share Posted October 17, 2005 Your system specs seems ok. With this system, are you able to connect your PSP to the PC via USB and facilitate simple non music file transfer? Quote Link to comment Share on other sites More sharing options...
D-Wade Posted October 17, 2005 Author Report Share Posted October 17, 2005 (edited) i could transfer pictures fine and i just successfully transfer an mp3 to my psp and it played fine but when i deleted it and tryed to transfer again it get me the error and same thing happen when i use sonicstage 3.2 it transfered successfully but when i deleted it and transfer again it wont transfer and get the error but it can convert to atrac 100%i could only transfer pictures but videos and musics i cantany solutions? =( Edited October 17, 2005 by D-Wade Quote Link to comment Share on other sites More sharing options...
Ishiyoshi Posted October 17, 2005 Report Share Posted October 17, 2005 D-Wade said: i could transfer pictures fine and i just successfully transfer an mp3 to my psp and it played fine but when i deleted it and tryed to transfer again it get me the error and same thing happen when i use sonicstage 3.2 it transfered successfully but when i deleted it and transfer again it wont transfer and get the error but it can convert to atrac 100%i could only transfer pictures but videos and musics i cantany solutions? =(←Since you did mentioned that you were able to facilitate ATRAC and Mp3 file transfer without any problems with other PCs, it is plausible to state that you may need to "overhaul" your current system. First, try a PC diagnostic test and if you can't discern any problem, I would suggest reinstalling WinXP. I am sorry I can't be of much help. Perhaps, someone else can offer some other alternatives. Quote Link to comment Share on other sites More sharing options...
D-Wade Posted October 17, 2005 Author Report Share Posted October 17, 2005 (edited) should i buy a new usb?i got this from the other site"Thanks everyone for the help that you gave to me.I finally found what caused the problem after I rang up to PSP technical support center yesterday.It is the hardware problem, USB cable, although the connection is fine through the cable, but that PSP usage USB cable cannot transfer data correctly (the professional said that is the design problem for the cable).Once I tried to change the USB cable, the problem solved!!! (curse that cable~~~)Well, finally I can store the files in my PSP, I am happy about that.Thank you guysCathy" Edited October 17, 2005 by D-Wade Quote Link to comment Share on other sites More sharing options...
Ishiyoshi Posted October 17, 2005 Report Share Posted October 17, 2005 It's plausible that the USB cable or even the USB connector of your PC could be faulty. But you'd mentioned that you could transfer picture related files with your current setup. It's strange that the USB cable or connector would be selective on file types. Well, there’s no harm trying a new USB setup. Good luck. Quote Link to comment Share on other sites More sharing options...
Christopher Posted October 17, 2005 Report Share Posted October 17, 2005 Welcome, D-Wade.Employing a USB hub may also cause this issue. If neither of those options work out, try reinstalling Sonicstage via the directions in the FAQ. Quote Link to comment Share on other sites More sharing options...
D-Wade Posted October 19, 2005 Author Report Share Posted October 19, 2005 (edited) nvm Edited October 20, 2005 by D-Wade Quote Link to comment Share on other sites More sharing options...
