kiklop Posted March 12, 2005 Report Share Posted March 12, 2005 HiI just bought nh700, and i am quite pleased with a quality of recording (PCM), which was my main reason to buy it.But i found something annoying and frustrating:If you transfer your (mic or line) recordings via usb, you can't repeat transfer again (in a case that you lose your recording somewhere in computer).I tried it intentionaly with test recording and with second transfer my recordings dissapeared from md.Of course, i have it still in my computer (2 copies), but i would still like to keep original recording on MD.Is there any workaround? Why is it happening? Copy protection?greetsKiklop Quote Link to comment Share on other sites More sharing options...
A440 Posted March 13, 2005 Report Share Posted March 13, 2005 You have just discovered the absolute worst feature of SonicStage. At least, I hope it's the worst feature. It is built in and there's no way around it, part of Sony's bizarre notion of Digital Rights Management. The good news is that SonicStage has been reliable for uploading since 2.3 . The only workaround is to play back the MD through your computer, with Sonic Stage controlling it, and use a soundcard recorder like Total Recorder to capture it as it plays in realtime. More here in the FAQ: http://forums.minidisc.org/index.php?showtopic=6330 Quote Link to comment Share on other sites More sharing options...
