tbcblues Posted March 18, 2005 Report Share Posted March 18, 2005 Newbie to Sonicstage - - is there a way to merge 2 or more tracks together into one before you transfer to the MD? I have version 2.0 and haven't found this topic in the help section yet. If it's not available on 2.0, do later versions have this feature? = thanks Quote Link to comment Share on other sites More sharing options...
mmp64 Posted March 22, 2005 Report Share Posted March 22, 2005 tbcblues said: Newbie to Sonicstage - - is there a way to merge 2 or more tracks together into one before you transfer to the MD? I have version 2.0 and haven't found this topic in the help section yet. If it's not available on 2.0, do later versions have this feature? = thanks←Yes, it is a feature in SS 3.0. Quote Link to comment Share on other sites More sharing options...
ROMBUSTERS Posted March 22, 2005 Report Share Posted March 22, 2005 download and upgrade to SonicStage 3.0 from www.connect.com Quote Link to comment Share on other sites More sharing options...
dex Otaku Posted March 22, 2005 Report Share Posted March 22, 2005 Edit -> CombineThis has been available since at least SS 2.1, though I don't actually know whether it will allow combining of any tracks in your library. I do know that it works with tracks that have been uploaded to SS after being recorded on the HiMD itself [i.e. with a mic or using line-in].This is probably in SS's help. Quote Link to comment Share on other sites More sharing options...
