Access Prohibited
scipio
I downloaded and installed SonicStage v3.0, which included Connect Music Store. When I tried to access CMS, I got the message: "Due to licensing restrictions..." - in short, I am not allowed access to download anything. Worse, when I try to access www.connect.com to download the mp3-to-atrac3+ batch encoder (this forum) I am transferred immediately to www.connect-europe.com.
Is there a way round this, does anyone know? Apart from removing SonicStage v3.0 and reinstalling the connect-europe version 2.3 I had before, that is. Although back to v2.3 is a reliable solution, it would be more time and money wasted - of which I have done a lot lately... sad.gif
The reason the majority of us don't run into this is because almost no one uses the Connect store.
While I did warn you about this already [that the only major difference between the different SS versions is where the Connect store heads to], I didn't offer the solution to the problem at that point.
You can change the URL that SS uses to go to the UK store instead.
Take a look at this thread:
http://forums.minidisc.org/index.php?showt...nge+connect+url
It seems unrelated, but the very last post has a link to a zip file with registry patches, including one for Connect Europe.
Cheers,
D.
