Sonicstage Doesn't Recognize Psp.
miroyle
I am getting frustrated now. Here's the deal:
I'm using my psp with the memory card from the value pack (32MB)
Windows 2000
SonicStage 3.0
Also, I formatted the memory card from my psp. I can access the psp fine from Windows Explorer. I have heard that you must have Windows Explorer closed for this to work, but I have tried this right after a reboot. I have tried connecting the psp before and after opening SonicStage, and the psp is in USB mode. Anyone know how to get this working? Thanks in advance for your help.
I do have the latest service pack for Windows 2000 (service pack 4). Ok, some more information:
No other programs wre running
No Codec packs installed
Usb version 2.0
Computer basic specs: Athlon 2500+ barton, 768 MB DDR 333 Ram
I have also tried different USB ports and cables.
edit: I just tried this on my friends computer running Windows XP and it worked fine. The problem is I can't access his computer whenever I need to. The computer fits the same description as mine except Windows XP and it has a Althlon 2000+.
Edited by miroyle
