sxc Posted April 11, 2005 Report Share Posted April 11, 2005 (edited) With the support of playlists in the NW-HD5, and the new way that Sonicstage sorts and stores music based on its ID tags, I thought that it may have improved the way it imports m3u playlists. Unfortunately I was wrong.Just for example you already have an mp3 file in your SonicStage library. If you then create a m3u playlist using Windows Media Player which includes this song, and then you import it to sonicStage, SS makes a duplicate entry of this song in your library. If you then transfer the playlist, it will re-transcode the mp3. So you will have 2 transcodings of the same mp3 file.How stupid is that?? Edited April 11, 2005 by sxc Quote Link to comment Share on other sites More sharing options...
zerodB Posted April 12, 2005 Report Share Posted April 12, 2005 sxc, there are a couple of threads in the "Hi-/MD Evaluations + Criticisms" forum devoted to SS 3.0 bugs & annoyances... perhaps you should post your gripes there. Try this one for starters: http://forums.minidisc.org/index.php?showtopic=8958 Quote Link to comment Share on other sites More sharing options...
