sulk Posted April 13, 2005 Report Share Posted April 13, 2005 Recently I bought some duracell rechargable batteries, and I've been using them fine. My MZ-N707, came with a Nickel Cadium battery, and when you put it on the stand, it will charge it, as long as its in there. I happened to put a NiMH battery into the unit, and put it on power, so i didnt have to use the battery, and it eventually auto turned off, and when I looked at it, it said it was charging it. So my question is, can/should the N707 be used to charge NiMH batteries, when its designed to chage nicd? I noticed on the duracell charging unit, thers a switch that has NiMH, and Nicd, so I'm assuming, theres a difference in the way it charges it, so is there a difference when charging the different types? It'd be helpful if someone just had a plain Yes, or no, etc, instead of redirecting me to battery university. Thanks-Sulk Quote Link to comment Share on other sites More sharing options...
StarknigHT Posted April 14, 2005 Report Share Posted April 14, 2005 not too sure about you, but when i still had a mz-n510, it would accept the NiMH batteries fine Quote Link to comment Share on other sites More sharing options...
Bananatree Posted April 14, 2005 Report Share Posted April 14, 2005 The n707 should be fine.Although I've never had any confirmed reports about one or the other. I've been through the manual for the n505 (which didn't come with a battery at all) and I didn't see anything about NiMhs Vs. NiCds, so I just went with it and charged my NiCD, even though it didn't say specifically that I could. Quote Link to comment Share on other sites More sharing options...
