gjkendall Posted April 14, 2005 Report Share Posted April 14, 2005 I am after a low end HI-md machine!I do not have a pc and would record using the optical from a hi-fi!Is this player any good?Whats it like compared to my existing unit...Sony mz-r501Thanks for any help/advice! Quote Link to comment Share on other sites More sharing options...
LowMD Posted April 14, 2005 Report Share Posted April 14, 2005 The NH600 is basically a player, though you can do a line-in recording with it. It's similar in functions to your R-501 except that it records on Hi-MDs, which can hold a lot more. But make sure someone is not selling you a NH600D. The D means it is just a downloader and does not have the line-in jack, so it would be useless to you without a PC. Quote Link to comment Share on other sites More sharing options...
zerodB Posted April 15, 2005 Report Share Posted April 15, 2005 In terms of the sorts of features - I'd say the 600 is exactly the same as your R501. Echoing LowMDs advice: just don't get a "600D"!!! Quote Link to comment Share on other sites More sharing options...
gjkendall Posted April 15, 2005 Author Report Share Posted April 15, 2005 zerodB said: In terms of the sorts of features - I'd say the 600 is exactly the same as your R501. Echoing LowMDs advice: just don't get a "600D"!!!←Thanks for the replies.....So I guess it's not really worth going for if it is not much different to what I alredy have.....I was interested in it, due to it being on sale for £50!What would you recommend as a unit then?Also, are there any decent bargains out there? Quote Link to comment Share on other sites More sharing options...
Wedge Posted April 15, 2005 Report Share Posted April 15, 2005 The biggest bargain was the MZ-NH900, which Amazon UK were selling for £69.99 in the past few weeks. Unfortunately, they have (not surprisingly) cleared their stocks of this unit.Next best bargain - although double the cost of what you were looking at, is the MZ-NH1, once again through Amazon UK for £109.99.The NH1 is the top-of-the-range 1st generation Hi-MD. £109.99 is a very good price on this if you are looking for a Hi-MD unit. Quote Link to comment Share on other sites More sharing options...
zerodB Posted April 16, 2005 Report Share Posted April 16, 2005 gjkendall said: So I guess it's not really worth going for if it is not much different to what I alredy have.....←Well, I meant it in the sense that the NH600 is sort of in the same catagory as the 501. They're both low-end, all plastic units powered by a AA battery and feature optical-in. The NH600 however, being Hi-MD, means you'll have the advantages of 1GB discs (= more music) to play with. I would consider a unit like the NH700. It's still backwards compatible, so you'll have the opportunity to record discs that still play nice with your old unit, but has a MIC in - you can do live recording + more.All in all, you probably aren't getting all the features Hi-MD has to offer unless you use it with a PC. Just my humble opinion tho. Quote Link to comment Share on other sites More sharing options...
