Listen To Md In The Car For Cheap
Yea smile.gif  but you still have to have a tuner in the car.. So it is not that that cheap for me..
Are there any car manufacturers that don't include at the very least an AM/FM radio, if not cassette and/or CD player any more? To the best of my knowledge, at least in North America, basically every car has come with a radio since some time in the 1960s or earlier.
If your car doesn't have a radio - try the junkyard. You can get factory-fit radios out of wrecks for as low as $10 around here.
Hi all!
Another suggestion would be to use a cheap low-power car amplifier and some cheap speakers such as those from a wreck. The low-power car amplifier could be one of those old car "power boosters" sold during the late 70s to early 80s.
Power the amplifier from the car's switched radio circuit. You may want to add an extra switch between the radio circuit and the amplifier's power input -- this could be obtained from a wreck of the same make and model as your car and filled in to a space in the dashboard. Wire the speakers from the amplifier's speaker output and connect the MD Walkman to the input terminals on the amplifier. You may get a decent sound out of the setup and yet be able to remove the MD Walkman from the car so it doesn't attract thieves.
With regards,
Simon Mackay
