smeagol Posted April 17, 2005 Report Share Posted April 17, 2005 i know this doesnt have a mic input but is there anyway of recording on this using a mic? im guessing u cant just use the line-in.thanks heaps for any help Quote Link to comment Share on other sites More sharing options...
Zappa Posted April 17, 2005 Report Share Posted April 17, 2005 The 600D doesnt have a line in. The 600 doesIf you have a mic and you wish to record via line in- you'll need a powersupply for the mic. Quote Link to comment Share on other sites More sharing options...
Jurriaan Posted April 17, 2005 Report Share Posted April 17, 2005 Assuming that you have a line-in and you don't need phantom power for your mic, I suggest that you buy yourself a cheap preamp like this one.I have a UB802 myself, which does have phantom power. To my opinion, these mixers (the UB series) have a very high value/money ratio. Quote Link to comment Share on other sites More sharing options...
smeagol Posted April 18, 2005 Author Report Share Posted April 18, 2005 Assuming that you have a line-in and you don't need phantom power for your mic, I suggest that you buy yourself a cheap preamp like this one.I have a UB802 myself, which does have phantom power. To my opinion, these mixers (the UB series) have a very high value/money ratio.←hmm im planning to use a shotgun mike- senheisser type- with its own battery- but because the minidisc player itself doesnt have a mic in getting this pre-amp will i be able to control the mic sensitivity (gain?) and be able to use the line in (becasuse theres no mic in?)thanks heaps guys Quote Link to comment Share on other sites More sharing options...
Wedge Posted April 18, 2005 Report Share Posted April 18, 2005 hmm im planning to use a shotgun mike- senheisser type- with its own battery- but because the minidisc player itself doesnt have a mic in getting this pre-amp will i be able to control the mic sensitivity (gain?) and be able to use the line in (becasuse theres no mic in?)thanks heaps guys←I suggest you re-read the first reply.If you've got a 600D rather than a 600, you CAN'T record at all. No mic-in, no line-in.(if I'm wrong, someone correct me!).I just don't want you spending money on gear that you won't be able to use. In the first instance, I suggest that you check your user manual. Quote Link to comment Share on other sites More sharing options...
dex Otaku Posted April 18, 2005 Report Share Posted April 18, 2005 The 'D' in any netMD's model number means Downloader.This means there are no recording inputs. It is for downloading via USB only.You will not be able to record from any live source with a 600D. Quote Link to comment Share on other sites More sharing options...
