Breepee2 Posted April 18, 2005 Report Share Posted April 18, 2005 I'm maybe going to buy a NetMD-deck. I want to record to MD via an optical cable, but I'd like to title via Sonicstage (because that's obviously easier and faster). Is this possible? And will it be possible to edit (merge, split, move, etc.) afterwards outside of Sonicstage, on the unit itself without any restrictions? As if titling was done on the unit? Quote Link to comment Share on other sites More sharing options...
Bananatree Posted April 18, 2005 Report Share Posted April 18, 2005 You can easily title using Sonicstage after recording from a deck. You can't directly edit the tracks, (merge, split) however you can move the tracks and groups around.Copy pasting titles from CD to Minidisc is really efficient, and Simple Burner is really good for that. Quote Link to comment Share on other sites More sharing options...
Breepee2 Posted April 18, 2005 Author Report Share Posted April 18, 2005 So once I add titles via Sonicstage, the music is 'locked'? Quote Link to comment Share on other sites More sharing options...
Breepee2 Posted April 19, 2005 Author Report Share Posted April 19, 2005 Can anyone confirm? Quote Link to comment Share on other sites More sharing options...
KJ_Palmer Posted April 19, 2005 Report Share Posted April 19, 2005 No, you can still edit the tracks (on a deck) after titling with sonicstage or simple burner. The track locking thing only applies to tracks recorded with the software... You should probably use SS 2.X or 3.0 to be sure though, as earlier versions are generally more restrictive... Quote Link to comment Share on other sites More sharing options...
