Mz-nf810 Remote Replacement
Finn88
Hi,
I have the MZ-NF810 AM/FM Minidisc player which has had a lot of use over the last 18 months since I bought it. My problem now is that one of the buttons on the remote has broken (the switch has broken off the circuit board), and now as a result I can not turn the volume up. All other functions still work. My question is what remote can I get to replace it with so I can still use radio etc. I've noticed the next generation of minidisc players (ie. the Hi-MD) use the same remote. Am I able to buy the same remote, or do some of the remotes that you can buy do the very same function.
If anyone can help me with this problem, it would be much appreciated.
Finn
The replacement of the turner remote for that problem would be expensive, the player itself can turn up or down the volumen so that would be the obvious solution besides you can keep using the turner. But if you really want a new remote, take a look of these:
http://www.audiocubes.com/index.php?cPath=...=3a&filter_id=6
http://servicesales.sel.sony.com/web/categ...emote%20Control
The SONY RM-MC33EL and the SONY RM-MC37LT are the remotes that you can look into.
