Mp3-songs On Minidisc...
...sometimes quiet and sometimes loud
Hello Forum,
since long time i have the problem that some of my MP3's that i copied to MiniDisc
(for my Car-Deck) with Sonic Stage are louder than others. I thought i depends on the MP3-Compression but i have MP3's with 256, some with 196 and they are at the same loudness-level. But on the other hand some MP3's with 196 are very loud and powerful in sound and bass.
Is there a software available to raise the loudness-level?
thanx in advance
haylebob
i found a solution!
After sending this posting i remember Steinbergs "WAVELAB" which is able to raise the Loudness of MP3-Files(and Wave-Files) by using "Loudness-Maximizer"
I do this last evening and it works!! Now my Songs are as loud as i want them biggrin.gif
I did not expectet that i have to work on MP3-Files which i have officially purchased...
thanx 4 your patience
see u
btw: greate forum!!
haylebob
By the way, bitrate (196, 256) has nothing to do with loudness. Bitrate is the quality of the compression. The loudness depends on the original material. If you have a high-bitrate version of a quiet recording, it will still be quiet.
that's correct (as i know now smartass.gif ) a friend of mine (he thinks he is an expert crazy.gif) told me this that a high bitrate raises the loudness and i believe it until i used Wavelab...
So does wavelab work like mp3gain? but 20 mb for a program that raises seems kinda big? Does anyone know if noth do the exact same thing? or is wavelab better at raising the volume on mp3s?
Hi,
i dont know mp3gain. Wavelab works on mp3-file, on many other formats more and i use it for a long time and i'm very satisfied with it.
haylebob
