Usb
BIGMLC420
if i have a mini disc player but not the usb cord that came with it will it still work
Yep - it will work, but you won't be able to connect to the PC via USB, although you could connect/play via the "in" jack on your sound card. The HiMD units use a standard USB cable, similar to that used by most cameras, so you should be able to buy one without too much difficulty. In fact, the ability to connect via USB and manage your files via Sonicstage (I have 3.1) is one of the major advantages over earlier MD units.
