Any Way To Split Songs In Sonicstage3?
jamie60509
This isn't a job for SonicStage.
You need an audio editing program like Audacity.
http://audacity.sourceforge.net
Copy the track from the CD onto your computer. Go to My Computer and Explore the CD drive. If all you see are 1KB .cda files then you need to get the .wav file. You can do that with CDex
http://cdexos.sourceforge.net/
which will list all the .wav files on the CD.
Copy the last song to your desktop, or wherever, and then open it (Shift held down, right-click, Open With... will be in the menu) with Audacity. You'll see the whole song as a waveform, and you can highlight/select and delete the silence, then highlight the hidden track and make a new file out of it. When you're done, instead of Save, use "Export as .wav." It's just like word-processing, only with a waveform.
