Ian Petrus Posted April 26, 2005 Report Share Posted April 26, 2005 Could somebody tell me how long can a recording last with a HiMD recorder, so that I can get a WAV file on my computer ?I was told that the WAV converter can only process files recorded in PCM mode, so the maximum duration would be only 1 h 34 min.What about Hi-SP and Hi-LP modes ? Is it also possible to convert ATRAC compressed files into WAV format ?Many thanks. Quote Link to comment Share on other sites More sharing options...
Christopher Posted April 26, 2005 Report Share Posted April 26, 2005 Welcome to the forums. In regards to your question - Yes, definitely. Quote Link to comment Share on other sites More sharing options...
Ian Petrus Posted April 27, 2005 Author Report Share Posted April 27, 2005 Could you be a little more explicit ? kurisu said: Welcome to the forums. In regards to your question - Yes, definitely.← Quote Link to comment Share on other sites More sharing options...
ozpeter Posted April 27, 2005 Report Share Posted April 27, 2005 Indeed you can convert files recorded in the Atrac modes - the only problem I could forsee is that the maximum size of a wave file (due to the RIFF header) is 4Gb, so if you had a huge single-track atrac file in theory you might hit the wave file limit. Quote Link to comment Share on other sites More sharing options...
Ian Petrus Posted April 28, 2005 Author Report Share Posted April 28, 2005 Assuming a 16 bit conversion at 44 KHz, it lets 12 hours !What puzzles me, is that Sony-France just replied me the exact opposite. For them, the Wav conversion is only possible with linear PCM recordings, not with ATRAC recordings.Looks odd, is'nt it ? Maybe French representatives are not up to date. ozpeter said: Indeed you can convert files recorded in the Atrac modes - the only problem I could forsee is that the maximum size of a wave file (due to the RIFF header) is 4Gb, so if you had a huge single-track atrac file in theory you might hit the wave file limit.← Quote Link to comment Share on other sites More sharing options...
