himdplayer Posted April 26, 2005 Report Share Posted April 26, 2005 Hi,Would anyone be able to tell me if it is possible to use the remote (RM-MC11EL) from a MZ-R909 with a MZ-710? Will any features be unusable on the remote etc?Thanks. Quote Link to comment Share on other sites More sharing options...
Ishiyoshi Posted April 26, 2005 Report Share Posted April 26, 2005 himdplayer said: Hi,Would anyone be able to tell me if it is possible to use the remote (RM-MC11EL) from a MZ-R909 with a MZ-710? Will any features be unusable on the remote etc?Thanks.←Yes, you can certainly employ the MC11EL with the N710. It should work fine. For further details, please refer to this Sony LCD Remote Guide. Quote Link to comment Share on other sites More sharing options...
zerodB Posted April 27, 2005 Report Share Posted April 27, 2005 Sorry to have to correct you Ishii, but some features will be unavailable. You won't be able to, for example, access the units menu and change settings through the remote. Some of the display modes act a little strange, but otherwise all the control functions and LCD work fine. Quote Link to comment Share on other sites More sharing options...
Ishiyoshi Posted April 27, 2005 Report Share Posted April 27, 2005 zerodB said: Sorry to have to correct you Ishii, but some features will be unavailable. You won't be able to, for example, access the units menu and change settings through the remote. Some of the display modes act a little strange, but otherwise all the control functions and LCD work fine.←No worries. Thanks for the clarification. Indeed, some functions will be unavailable. Quote Link to comment Share on other sites More sharing options...
