Guest Stuge Posted November 1, 2005 Report Share Posted November 1, 2005 can anyone tell how can i remove that connect music store from new ss v3.3.as it is irritating me a lot Quote Link to comment Share on other sites More sharing options...
Ishiyoshi Posted November 1, 2005 Report Share Posted November 1, 2005 can anyone tell how can i remove that connect music store from new ss v3.3.as it is irritating me a lot←I believe you can remove the Music Service module by deleting the EMD entry within SonicStage 3.3's registry.--> try and locate [HKEY_LOCAL_MACHINE\SOFTWARE\Sony Corporation\SonicStage\EMD]; then delete it. That should take care of it. If you have any other queries pertaining to this issue, please create a new thread within "Software" section and we will assist you accordingly. Quote Link to comment Share on other sites More sharing options...
Guest Stuge Posted November 1, 2005 Report Share Posted November 1, 2005 I believe you can remove the Music Service module by deleting the EMD entry within SonicStage 3.3's registry.--> try and locate [HKEY_LOCAL_MACHINE\SOFTWARE\Sony Corporation\SonicStage\EMD]; then delete it. That should take care of it. If you have any other queries pertaining to this issue, please create a new thread within "Software" section and we will assist you accordingly.←thanx but it didn`t work at all.therefore i will post a new topic under "software" section Quote Link to comment Share on other sites More sharing options...
Guest Stuge Posted November 1, 2005 Report Share Posted November 1, 2005 Can anyone help me soo that i can remove connet music store from my ss ver 3.3.I have tried registry edting but it didn`t work at all. As it is irritating me a lot.Pl Help!........... Quote Link to comment Share on other sites More sharing options...
Ishiyoshi Posted November 1, 2005 Report Share Posted November 1, 2005 It seems to work for lxrichbirdxl:It worked for me.Select 'Run' from start menu, enter 'regedit', then go to HKEY_LOCAL_MACHINE to SOFTWARE to Sony Corporation to SS to EMD then delete all entry with CONNECT or something. ←Try again. Quote Link to comment Share on other sites More sharing options...
Guest Stuge Posted November 1, 2005 Report Share Posted November 1, 2005 It seems to work for lxrichbirdxl:Try again. ←THANX to u all it worked for me this time.... Quote Link to comment Share on other sites More sharing options...
