AcTs Posted May 3, 2005 Report Share Posted May 3, 2005 Hello everyone.. I tried to look this up.. found alot of questions pertaining to the quality and which is best for recording.. but nothing along the lines I need. I had SS 2.3 I think it was.. and it has atrac3+ which I used to encode @ 67kbps? Well when I upgraded to the US version of SS 3.01 it no longer has atrac3+ as an encoding feature! Only (there are of course other bitrates... just no more atrac3+ in the encoding options) atrac3 @ 66 kbps. Is this the same as the atrac3+ @ 67kbps? I apologize if this has beed adressed but after wading through 5 pages with no answers after searching I had to ask. Any help is appreciated. Thanks to all who reply.. -AcTs Quote Link to comment Share on other sites More sharing options...
jadeclaw Posted May 3, 2005 Report Share Posted May 3, 2005 Ahem, That's new.I've had the 3.0 as well as the 3.1 and both offer all default bitrates.However, if you don't have a Hi-MD unit, it might not offer the Atrac3+-bitrates for transfer onto MD.LP4@66k cannot be directly compared with Hi-LP@64k, as LP4 suffers from low channel separation.On the other paw, LP4 has slightly less artefacts, so it could sound a little bit better.When importing/ripping, it should always offer all modes. Quote Link to comment Share on other sites More sharing options...
AcTs Posted May 4, 2005 Author Report Share Posted May 4, 2005 Well I have a hi-md.. the rh10.. it worked fine with the 2.3.. as atrac3+ was in the drop down menu for settings.. but in the update dversion.. it only has atrac3.. no + in sight.. sigh... I guess I will have to live with atrac3 ... -AcTs jadeclaw said: Ahem, That's new.I've had the 3.0 as well as the 3.1 and both offer all default bitrates.However, if you don't have a Hi-MD unit, it might not offer the Atrac3+-bitrates for transfer onto MD.LP4@66k cannot be directly compared with Hi-LP@64k, as LP4 suffers from low channel separation.On the other paw, LP4 has slightly less artefacts, so it could sound a little bit better.When importing/ripping, it should always offer all modes.← Quote Link to comment Share on other sites More sharing options...
gmdisc Posted May 4, 2005 Report Share Posted May 4, 2005 AcTs said: Well I have a hi-md.. the rh10.. it worked fine with the 2.3.. as atrac3+ was in the drop down menu for settings.. but in the update dversion.. it only has atrac3.. no + in sight.. sigh... I guess I will have to live with atrac3 ... -AcTs←Makes no sense at all. Are you sure you're using a disc in Hi-MD mode? If it is in regular MD mode it will not give you the option of transferring in atrac3+ formats. Quote Link to comment Share on other sites More sharing options...
AcTs Posted May 4, 2005 Author Report Share Posted May 4, 2005 Yes.. I am using the 1 gb disc formatted in Hi-md.. I just uninstalled everything and reinstalled and voila.. it is now there! thanks all! -AcTs gmdisc said: Makes no sense at all. Are you sure you're using a disc in Hi-MD mode? If it is in regular MD mode it will not give you the option of transferring in atrac3+ formats.← Quote Link to comment Share on other sites More sharing options...
1kyle Posted May 5, 2005 Report Share Posted May 5, 2005 AcTs said: Yes.. I am using the 1 gb disc formatted in Hi-md.. I just uninstalled everything and reinstalled and voila.. it is now there! thanks all! -AcTs←Mine works fine (Open MG audio - ATRAC3plus 256Kbps) is an option to rip CD's from and tranferring to MD I get all the options.Using SS 3.1Cheers-K Quote Link to comment Share on other sites More sharing options...
