Erase Vs Reformat
If you use the discs for Music only, it doesn't matter, if you format or do an All Erase.
I say, format it after use, so you know, that it runs the full time.
You don't have to erase it before doing a Format.
*Warning*
Format deletes all non-Music data as well.
Thats what I want is a clean start,
Thanks for the input. jadeclaw
