BillyBoy Posted May 10, 2005 Report Share Posted May 10, 2005 Is there any advantage in using the mic with the internal battery power turned on.. or is it better to turn the battery power off.. and use the power from the minidisc?? thanks Quote Link to comment Share on other sites More sharing options...
cbud Posted May 13, 2005 Report Share Posted May 13, 2005 Is there any advantage in using the mic with the internal battery power turned on.. or is it better to turn the battery power off.. and use the power from the minidisc?? thanks←What type of mic are you using?The power coming from a minidisc to a mic is practically nothing. Giving a condenser mic more power helps it's performance. So, yes, turn it on. Quote Link to comment Share on other sites More sharing options...
BillyBoy Posted May 13, 2005 Author Report Share Posted May 13, 2005 What type of mic are you using?The power coming from a minidisc to a mic is practically nothing. Giving a condenser mic more power helps it's performance. So, yes, turn it on.←Thanks Bud,I'm usung a Sony ECM-719 mic Quote Link to comment Share on other sites More sharing options...
