ViToM3 Posted May 10, 2005 Report Share Posted May 10, 2005 hi, i wath and read like 3 hours this forum hhehehe its a nice forum congrats, but i didint foud a concret answer for my problem, i convert the files (mp3) into lp4 the hole album its 8 songs, then transfer 7 songs and the last one the number 8 says trsnfer error the next son or song can transfer, well i try to put in normal trnasfer (standard), then i try teh second option (lp4) and the third option, and isnt working the last song cant be transfer, i have soncistage 3.1 and works fine with the 7 songs and fast but the last song cant be trnasfer i try to close the program and nothing i reset pc and same, can anybody plz help me, thx bye Quote Link to comment Share on other sites More sharing options...
Ishiyoshi Posted May 10, 2005 Report Share Posted May 10, 2005 ViToM3 said: hi, i wath and read like 3 hours this forum hhehehe its a nice forum congrats, but i didint foud a concret answer for my problem, i convert the files (mp3) into lp4 the hole album its 8 songs, then transfer 7 songs and the last one the number 8 says trsnfer error the next son or song can transfer, well i try to put in normal trnasfer (standard), then i try teh second option (lp4) and the third option, and isnt working the last song cant be transfer, i have soncistage 3.1 and works fine with the 7 songs and fast but the last song cant be trnasfer i try to close the program and nothing i reset pc and same, can anybody plz help me, thx bye←Perhaps the 8th song is a VBR or CBR Mp3? If it is, try and use software like dBpowerAMP and convert the mp3 in question (assuming it is a VBR/CBR type) into non-VBR/CBR Mp3. Then try converting this non-VBR/CBR Mp3 into LP4 with SonicStage. Quote Link to comment Share on other sites More sharing options...
ViToM3 Posted May 11, 2005 Author Report Share Posted May 11, 2005 hey thx man, i closed the program and reopne it and works, the osng was mp3, but i post a new topic witha wird error, thx anyway and i hope u guys can help me thx. Quote Link to comment Share on other sites More sharing options...
