Tracks Won't Play
Remington
I recorded a concert last night in Hi-LP mode on a standard 80-minute disc with my NH900 but I have a problem. When I try to play back the tracks, the display screen shows "00:00" and the little disc symbol keeps spinning like the player is searching for a track but the track never gets played. I've never run into this kind of problem when I've recorded before. What am I missing? blink.gif
Could be a bad disc, unfortunately. Try hooking up the USB and opening SonicStage and see if you can play the disc back with SonicStage's player, which saved one unplayable disc I had. If you can, then either have SonicStage play back the disc and use TotalRecorder to record it in realtime, or try uploading the tracks.
