Will It Work?
alice84
Hi, I am new to this whole mini disc thing, so please bear with me! I beleive I have a Sony Minidisc Net MD Walkman MZ-N510 TYPE S (whatever that means).
When I bought it, it came with Simple Burner. However, I lost the disc in a recent move and now have mac. After searching the net, I found a petition and it seems that you cannot use the minidisc with a mac. Is there anything I can do? I already have songs on the Itunes I want to put on the minidisc. It is too late to take the minidisc player back. Any suggestions would be greatly appreciated. Thank you.
2 suggestions from me, actually 3, but only 2 related to your question.
1st: What kind of Mac do you have? The most recent G5 towers have Optical outs in the back. So with a 12 dollar fibre optic cable, you can easily play your songs in iTunes and record them using the optical in of your N510. If you just have something else, you can get a USB to optical converter that will make your iTunes music play through USB to optical and you can record it in real-time. Or if you don't want to buy anything else, try the headphone/speaker/line out of your computer into the line-in.
2nd: Dig out that old PC and use it as your "Junker" for use with your NetMD recorder.
3rdly: There are 2 active topics in the software forum about Mac OSX and NetMD/HiMD, you really should have either done a search, or just looked around the forum a bit before you made this post.
