bachoco Posted May 28, 2005 Report Share Posted May 28, 2005 Hi everyone, i tried to install the simple burner software in WIN 2000 , and i get the error " NetMDSB.exe has generated error and will be closed by windows" I reboot the pc, remove the software and install it again, without sucessPlease tell me what can i do thanks in advancebachoco Quote Link to comment Share on other sites More sharing options...
Ishiyoshi Posted May 29, 2005 Report Share Posted May 29, 2005 Hi everyone, i tried to install the simple burn software in WIN 2000 , and i get the error "NetMDSB.exe has generated error and will be closed by windows" I reboot the pc, remove the software and install it again, without sucessPlease tell me what can i do thanks in advancebachoco←Welcome to MDCF!First of all, please refer to the Software FAQs and post back with your system specs. We will try and assist you from there.In addition, you can refer to this thread for possible solution to your predicament. Quote Link to comment Share on other sites More sharing options...
