elpedro Posted June 5, 2005 Report Share Posted June 5, 2005 Just checking to see if there is any interest in doing something like this. I think it would be nice to a Line In and DC In. From what I have seen all ppl would need is the dc plug and audio port and some minor soldering and wires. The Nh600d has the holes for the ports and the board has the provisions for it. I thinking the function for an audio in and dc in are just turned off and and can get toggled on via the service menu but I have no clue how to translate the service menu right now (need to do more research). If anyone has any information on how do the upgrade or has done it or is willing to help figure stuff out, just drop a line.Thanks everyone and anyone! Quote Link to comment Share on other sites More sharing options...
jonny mac Posted June 5, 2005 Report Share Posted June 5, 2005 That's a lot of hastle? Is it really worth it? If these functions are that important you should have got the NH700 Quote Link to comment Share on other sites More sharing options...
StarknigHT Posted June 5, 2005 Report Share Posted June 5, 2005 if u want a service manual for 600dhttp://forums.minidisc.org/index.php?showt...120entry58745its on that page Quote Link to comment Share on other sites More sharing options...
elpedro Posted June 6, 2005 Author Report Share Posted June 6, 2005 elpedro said: Just checking to see if there is any interest in doing something like this. I think it would be nice to a Line In and DC In. From what I have seen all ppl would need is the dc plug and audio port and some minor soldering and wires. The Nh600d has the holes for the ports and the board has the provisions for it. I thinking the function for an audio in and dc in are just turned off and and can get toggled on via the service menu but I have no clue how to translate the service menu right now (need to do more research). If anyone has any information on how do the upgrade or has done it or is willing to help figure stuff out, just drop a line.Thanks everyone and anyone! ←Not really, getting the appropriate dc port and audio port is really easy and cheap (less than 5 bucks canadian) and soldering is really quick. Find a drill bit that is a tad bigger than the port so it can stick out. The major part will be getting any use out of the ports after you attach them, which is where the service mode comes in. Oh thanks starknight for the link, will go thru. Quote Link to comment Share on other sites More sharing options...
javajeb Posted June 7, 2005 Report Share Posted June 7, 2005 elpedro said: Just checking to see if there is any interest in doing something like this. I think it would be nice to a Line In and DC In. From what I have seen all ppl would need is the dc plug and audio port and some minor soldering and wires. The Nh600d has the holes for the ports and the board has the provisions for it. I thinking the function for an audio in and dc in are just turned off and and can get toggled on via the service menu but I have no clue how to translate the service menu right now (need to do more research). If anyone has any information on how do the upgrade or has done it or is willing to help figure stuff out, just drop a line.Thanks everyone and anyone! ←I would be interested. I'm waiting on my 600D to arrive. Should be here tomorrow. Line in is not a make or break for me, but would be cool!javajeb Quote Link to comment Share on other sites More sharing options...
jadeclaw Posted June 8, 2005 Report Share Posted June 8, 2005 Adding LineIn/Optical and DC in?Forget it.After checking the Service Manual, I see, that the relevant areas on the main board are unpopulated.In other words: Adding the sockets is of no use as the necessary electronics are missing.Solution: Get a european NH600 or get one of the higher models except the DH10 & DH710. Quote Link to comment Share on other sites More sharing options...
elpedro Posted June 8, 2005 Author Report Share Posted June 8, 2005 jadeclaw said: Adding LineIn/Optical and DC in?Forget it.After checking the Service Manual, I see, that the relevant areas on the main board are unpopulated.In other words: Adding the sockets is of no use as the necessary electronics are missing.Solution: Get a european NH600 or get one of the higher models except the DH10 & DH710.←"unpopulated"? not sure what you mean but I have went through the service manual the main chip has a line in and mic in, I'll post the line on the chip later. I have just opened my nh600d to see if there is anything where the dc in and audio in are I found the holes for putting the necessary parts are made, just need the parts (ie the audio port and dc in plug).Im going to check to see if the port holes actually go to the chip. I will laugh and be shocked if all that needs to be done is a soldering in the ports and enabling the functions via service mode hack.... back in a bit[attachmentid=349][attachmentid=350] Quote Link to comment Share on other sites More sharing options...
elpedro Posted June 8, 2005 Author Report Share Posted June 8, 2005 javajeb said: I would be interested. I'm waiting on my 600D to arrive. Should be here tomorrow. Line in is not a make or break for me, but would be cool!javajeb←Thanks for your interest Quote Link to comment Share on other sites More sharing options...
jadeclaw Posted June 9, 2005 Report Share Posted June 9, 2005 elpedro said: "unpopulated"? not sure what you mean but I have went through the service manual the main chip has a line in and mic in, I'll post the line on the chip later. I have just opened my nh600d to see if there is anything where the dc in and audio in are I found the holes for putting the necessary parts are made, just need the parts (ie the audio port and dc in plug).Im going to check to see if the port holes actually go to the chip. I will laugh and be shocked if all that needs to be done is a soldering in the ports and enabling the functions via service mode hack.... back in a bit[attachmentid=349][attachmentid=350]←So, to show, what is missing, I edited the second pic a bit...Look at the pointers in white.And you really thought, Sony would solder parts in, that are not needed?Silly you... Download the Service manual for the NHF800/NH700 too and compare the silkscreen drawings.The NH700 has the same circuit board, only with a few more parts on it.The relevant pages are: Page 23 in the NH600D service manualPage 35 in the NH700 service manual.By the way, unpopulated means, that there are no parts soldered in. Quote Link to comment Share on other sites More sharing options...
elpedro Posted June 9, 2005 Author Report Share Posted June 9, 2005 jadeclaw said: So, to show, what is missing, I edited the second pic a bit...Look at the pointers in white.And you really thought, Sony would solder parts in, that are not needed?Silly you... Download the Service manual for the NHF800/NH700 too and compare the silkscreen drawings.The NH700 has the same circuit board, only with a few more parts on it.The relevant pages are: Page 23 in the NH600D service manualPage 35 in the NH700 service manual.By the way, unpopulated means, that there are no parts soldered in.←Thanks for pointing that out. Is there a service manual and shots (front and back) of the nh600 board out anywhere or can some one take a photo of the front and back of their nh600. Cause even voltage regulators and other parts I can buy from my electronic store and install. Though I think the software side of this upgrade is not even there, missing the lines of code for the rec function (still verifying).Attached is the back side of the main board if anyone wants to see. for the audio in, the wiring goes to a dead but I believe that justneeds to get connected to another point on the board.[attachmentid=353] Quote Link to comment Share on other sites More sharing options...
elpedro Posted June 9, 2005 Author Report Share Posted June 9, 2005 hahha yeah Im being very persistant about this, its just b/c I want to make sure it is completely impossible before I give up. I find modding out electronics to be fun so if I can do it with my nh600d then I will.... though if I fuck it I won't have an md for a while ... Quote Link to comment Share on other sites More sharing options...
jadeclaw Posted June 10, 2005 Report Share Posted June 10, 2005 The A/D-Converter might be available as a sample from Asahi Kasei,but getting the voltage regulator might pose a problem.Plus, how do you want to solder the part in?You need special tools for that, costing in excess of thousand dollar.There is no way to solder in a Ball Grid Array with a conventional soldering iron.Just ask someone, who services cell phones down to chip level,as these contain similar parts and he will confirm that.Do yourself a favor - Get a NHF800 and be happy.It is far less hassle and much cheaper. Quote Link to comment Share on other sites More sharing options...
