Sony Mz-r30 Replacement Headphones
chris_de_wet
Can anyone suggest approaches for connecting a new set of earphones to the Sony MZ-R30 remote?
Is there an adapter from 3.5mm/2.5mm to micro-jack, for example?
Many thanks for all advice.
Chris
I am not familiar with the MZ-R30's remote. However, I think you can utilize the Sony PC-MP1S micro plug to connect your earphone in question to the MZ-R30's remote. The PC-MP1S micro plug connects stereo mini-plug to micro-plug and it is about 0.1 m in length.
user posted image
user posted image
That adapter should do the job.
Is it available in the UK?
Can anyone advise?
Thanks.
Chris
