simonb Posted November 14, 2005 Report Share Posted November 14, 2005 Hi,I've downloaded the US, European and Jap versions of the firmwares but I just cant seem to apply the latest firmware to my nw-e407. 1. I click on fwupdater.exe2. Sony Network Walkman Software Update tool (1/3) box appears saying "connect the device etc etc...". I click OK.3. Then I constantly get the message: "The application cannot run because the system information cannot be found.". So I have to click OK.I can use the mp3 manager v2 and put mp3's onto the stick fine, and it plays everything i put into it but I just cant muster this firmware.Any suggestions anyone?Cheers,Simon Quote Link to comment Share on other sites More sharing options...
0 bogon07 Posted November 14, 2005 Report Share Posted November 14, 2005 try following the step by step instructions on Sony's Pacific support site using the firmware for your own countryNetwork Walkman NW-E403/E405/E407 Firmware Upgrade Programhttp://www.css.ap.sony.com/consumer/templa...=Personal+Audio Quote Link to comment Share on other sites More sharing options...
0 Guest Stuge Posted November 15, 2005 Report Share Posted November 15, 2005 (edited) Note there r different firmware for both nw-500 series & nw-e400 series.download the right firmware for ur player from the above given link.& tell us whether it worked for u or not Edited November 15, 2005 by Stuge Quote Link to comment Share on other sites More sharing options...
0 simonb Posted November 15, 2005 Author Report Share Posted November 15, 2005 (edited) I'm downloading the right firmware (I guess). I downloaded the firmware from the above link (NW-E40X_V2_0C.exe) and on the back of the player it says that the model is NW-E407. Serial number starts with 50#####.. Oh, and I purchased the player from a shop in London.The files extracted are:FWUpdater.exeFWUpdaterCom.dllFWUpdaterRes.dllMSFWUPGR_NW-E40X_201C.UPGNW-E40X_V2_0.iniOne question, do you HAVE to use the original sony USB cable? The cable I have works fine with the MP3 manager. Edited November 15, 2005 by simonb Quote Link to comment Share on other sites More sharing options...
0 Guest Stuge Posted November 15, 2005 Report Share Posted November 15, 2005 I have chatted with sony analyst & this is what he has to say.I didn`t told him that i was from India(www.esupport.sony.com)may this helps u... Analyst sony_ is here and your issue status is: working Problem: Unable to update update the firmware for the NW-E407 playerEnd Session user stuge has entered roomanalyst stuge_ has entered roomsony_> Welcome to Sony Online Support. I will be glad to assist you.sony_> Hi Robin.stuge> Hisony_> Are you trying to update the firmware for the NW-E407 player?stuge> Yeahsony_> May I know the operating system installed in your Computer?stuge> WINDOWS XPstuge> I FIRST GET THE FOLLOWING =Sony Network Walkman Software Update tool (1/3) box appears saying "connect the device etc etc...". I click OKstuge> Then I constantly get the message: "The application cannot run because the system information cannot be found.". So I have to click OKstuge> i Don`t understand this message at allsony_> Are you following the instructions given on the page from where you have downloaded the firmware? stuge> yessony_> Please make sure that the player is not connected while installing the firmware. sony_> I am sorry for the confusion. stuge> Then how will install the firmware to the player?sony_> Please make sure that the player is connected while installing the firmware. sony_> I also suggest that you close all the SonicStage software if it is running. stuge> Does i need to do anything else?sony_> Robin, I will forward the link where you can view the instructions to install the firmware.sony_> http://esupport.sony.com/perl/swu-download...7,16&mdl=NWE407stuge_> Please click on the link and it will open in a new page.sony_> Are you able to view the page?stuge> Yessony_> Please follow the instructions given under "Download and Installation Instructions" to install the firmware correctly. stuge> thaNX.sony_> If you are using Windows XP operating system, be sure that you are logged in as the Administrator or as a user with Administrative rights, during the installation of this update Quote Link to comment Share on other sites More sharing options...
0 simonb Posted November 15, 2005 Author Report Share Posted November 15, 2005 It seems that there's two versions of the .upg file. Sony Chat Support gave me this link: http://esupport.sony.com/perl/swu-download...id=1925&os_id=7and it has MSFWUPGR_NW-E40X_200C.UPG which upgraded my NW-E407. However, the verison I was using was MSFWUPGR_NW-E40X_201C.UPG which didn't work.I dont understand the differences between the two however 200C.UPG worked. Quote Link to comment Share on other sites More sharing options...
0 simonb Posted November 15, 2005 Author Report Share Posted November 15, 2005 (edited) And to add a bit more into it.... the original upgrade firmware i downloaded (201) has worked for the first time after I upgraded the NW-E407 with 200. Edited November 15, 2005 by simonb Quote Link to comment Share on other sites More sharing options...
0 Guest Stuge Posted November 15, 2005 Report Share Posted November 15, 2005 simonb.I also doesn`t understand so much of technical thing.Sony never told us about that.I think that "200" was the first one which sony might have uploded for the upgrade & 201 is the newer version(means better than the previous one, i think so)for eg I think here "200" means 2 firmware & "201" is 2.1 firmware upgrade.Thats why u were not able to upgrade ur firmware via 201 b`coz it is newer(it might need the older version i.e 200) but i`m happy that ur problem is solved. Quote Link to comment Share on other sites More sharing options...
simonb
Hi,
Cheers,
Simon
7 answers to this question
