Sonicstage 2.3 Not Showing Names
daymouse
Hi
Admin could you please close my other post as i have moved onto sonicstage 2.3
Thanks
But could anyone help with 2.3
The problem is when i import into the library nearly all my albums just come up as cd1 and cd2
so i just have a massive list of albums called cd1 and cd2 of wich i cant tell which album is which.
Even though i have used a program to update all my id3v tags to make sure all fields are correct in every album.
The strange thing is if i import them all in itunes it works fine.
Where does sonic get this information from and how can i fix it??
Thanks.
