jboss Posted July 2, 2005 Report Share Posted July 2, 2005 (edited) My current rig is simply a SP-BMC-2 > MZ-R30 (Don't laugh, it's solid, and HiMD is a bit out of my price-range).I'm really debating hard on buying a preamp.I had used my friend's Shure studio Condenser with an XLR > 1/4" adapter to a 1/4" > 1/8" adapter. Although the adapters stuck 6 inches out of my pocket and I had to carry 15 feet of cable, I got a very nice (albiet mono) recording of a local rock show with no overloads. With this confidence, I took the same rig to see The Black Keys a few weeks later. Two things went wrong. I accidently set my mic sensitivity to 'High', and the adapters wereacting bad. There was so much weight that they woiuldn't sit right in the mic jack, causing static and even a dropout where it lost signal completely. After this I decided that I needed my own mics... and to check the mic sensitivity every time I recorded.I made some stereo binaural mics using RadioShack Mic capsules soldered into a gold plugged stereo audio cable. Took those puppies to a show and... major static. I wasn't completely sure it was a preamp overload, being unsure of my soldering skills and the quality of the cheap RadioShack capsules. I finally decided to buy a SP-BMC-2 mic set from eBay.When I went to a show last week, I brought them along and, sure enough, static. This time I was positive it was the preamp overloading. Although one performance came out sounding okay because the left mic is at slightly lower volume, so I was able to isolate that one channel that didn't overload during this quieter performance.Anyway, all of that aside, I'm debating between just buying a cheap RadioShack volume attenuator, or splurging and buying a preamp. I don't have much money, but I'm kind of keeping close watch on eBay for good deals.My main concern is that:-The RadioShack cable may add line noise (which, since all my transfers are analog, I really don't need any extra).-The RadioShack cable wears out, from what I've read. That would be bad if it did that during a recording.-A preamp may benefit me by giving me the extra power I'd need to get full range from my mics whilst also being more high quality than the crappy MD preamp.-A preamp would be awesome if I went to upgrade my MD to a HiMD, since HiMDs with only a line-in and no mic-in tend to be cheaper.The drawback, of course is the cost of the preamp. On eBay there is a Visivox brand preamp I can get shipped for $63. That's really hard for me to manage financially, but I could do it. I'm not so sure how much I can trust that one, though. I've never heard anything about Visivox, so I'm a little hesitant to buy that.http://cgi.ebay.com/ws/eBayISAPI.dll?ViewI...AMEWA%3AIT&rd=1I'm also keeping an eye on a Sound Professionals preamp on there too.Basically, how big of an advantage is a Preamp > Line-in over a RadioShack Attenuator > Mic-in?Any advice? Edited July 2, 2005 by jboss Quote Link to comment Share on other sites More sharing options...
Reactive Posted July 2, 2005 Report Share Posted July 2, 2005 Your best bet (given your budget) would be to use a battery box http://www.reactivesounds.com/ps1.php. For recording loud concerts your need to power those mic's as much as possible, throw in a radio shack attenuator and you can adjust the mic's output so that you don't overload the minidisc internal pre-amp. Gerrywww.reactivesounds.comMy current rig is simply a SP-BMC-2 > MZ-R30 (Don't laugh, it's solid, and HiMD is a bit out of my price-range).I'm really debating hard on buying a preamp.I had used my friend's Shure studio Condenser with an XLR > 1/4" adapter to a 1/4" > 1/8" adapter. Although the adapters stuck 6 inches out of my pocket and I had to carry 15 feet of cable, I got a very nice (albiet mono) recording of a local rock show with no overloads. With this confidence, I took the same rig to see The Black Keys a few weeks later. Two things went wrong. I accidently set my mic sensitivity to 'High', and the adapters wereacting bad. There was so much weight that they woiuldn't sit right in the mic jack, causing static and even a dropout where it lost signal completely. After this I decided that I needed my own mics... and to check the mic sensitivity every time I recorded.I made some stereo binaural mics using RadioShack Mic capsules soldered into a gold plugged stereo audio cable. Took those puppies to a show and... major static. I wasn't completely sure it was a preamp overload, being unsure of my soldering skills and the quality of the cheap RadioShack capsules. I finally decided to buy a SP-BMC-2 mic set from eBay.When I went to a show last week, I brought them along and, sure enough, static. This time I was positive it was the preamp overloading. Although one performance came out sounding okay because the left mic is at slightly lower volume, so I was able to isolate that one channel that didn't overload during this quieter performance.Anyway, all of that aside, I'm debating between just buying a cheap RadioShack volume attenuator, or splurging and buying a preamp. I don't have much money, but I'm kind of keeping close watch on eBay for good deals.My main concern is that:-The RadioShack cable may add line noise (which, since all my transfers are analog, I really don't need any extra).-The RadioShack cable wears out, from what I've read. That would be bad if it did that during a recording.-A preamp may benefit me by giving me the extra power I'd need to get full range from my mics whilst also being more high quality than the crappy MD preamp.-A preamp would be awesome if I went to upgrade my MD to a HiMD, since HiMDs with only a line-in and no mic-in tend to be cheaper.The drawback, of course is the cost of the preamp. On eBay there is a Visivox brand preamp I can get shipped for $63. That's really hard for me to manage financially, but I could do it. I'm not so sure how much I can trust that one, though. I've never heard anything about Visivox, so I'm a little hesitant to buy that.http://cgi.ebay.com/ws/eBayISAPI.dll?ViewI...AMEWA%3AIT&rd=1I'm also keeping an eye on a Sound Professionals preamp on there too.Basically, how big of an advantage is a Preamp > Line-in over a RadioShack Attenuator > Mic-in?Any advice?← Quote Link to comment Share on other sites More sharing options...
jboss Posted July 2, 2005 Author Report Share Posted July 2, 2005 Thanks for the advice, I'll look into that. Quote Link to comment Share on other sites More sharing options...
