Simple Burner 2 --> Record On Stereo standard Only
Mikolson
There is no such thing as actual SP transfers via USB. There is a compatibility mode that sends repackaged LP2 audio to the recorder, but alas, this is LP2 as encoded by SS or SB, not the real thing.
If you want actual SP, you have to do realtime optical or analogue transfers.
  • 3 weeks later...
somewere i can record to md by SS on sp standard, it's sure that impossible tu record by SB?
