echo3 Posted July 8, 2005 Report Share Posted July 8, 2005 I've searched the forums for hours but can't find an answer.I've just got a new Sony MZ-NH700. I've tried recording a few CDs direct with Simple Burner and mp3 files with Sonic Stage. I keep getting a barely inaudible "click" every 100 seconds or so on the recording when I play it back. Its not the minidisc jumping, as if you rewind the clicks are always in the same place. It sounds like the sound dies for 1/100th of a second or less.Have I got a faulty unit - or am I doing something wrong. I've tried re-installingt eh software onto a different (brand new) laptop and the resulst are the same.Any ideas?TIA,e3. Quote Link to comment Share on other sites More sharing options...
Christopher Posted July 8, 2005 Report Share Posted July 8, 2005 Welcome to the forums. Try recording manually through the mic or opticial in connections and see what the result is. Also, where is the USB cord plugged in? Straight into the computer or into a hub? Quote Link to comment Share on other sites More sharing options...
echo3 Posted July 8, 2005 Author Report Share Posted July 8, 2005 thanks,last night's try was through a hub - why would that make a difference? do you think something is intefering with the data transfer?e3. Quote Link to comment Share on other sites More sharing options...
Christopher Posted July 8, 2005 Report Share Posted July 8, 2005 It's definitely possible and has happened to others in the past. Try a straight connection into the computer. Quote Link to comment Share on other sites More sharing options...
echo3 Posted July 10, 2005 Author Report Share Posted July 10, 2005 It's definitely possible and has happened to others in the past. Try a straight connection into the computer.←tried and failed, with MD simple burner and Sonic Stage writing to HiSP there is always a gap - sounds like a track break. Different place each time.I'm beginning to think my unit is faulty, as surely none of the audiophiles that worship MD would stand for it.S. Quote Link to comment Share on other sites More sharing options...
