Sonicstage 3.1 Problem
Manolo Caracol
First of all, excuse my English
I have a happy new user of the NW-HD5. All it's fine, but SonicStage software is giving me a headache.
I am trying to import to atrac my CD collection. Well, when I have finished a CD and put a new one in the PC, Sonic Stage still thinks that is the previous one. I press the CD information button several times, but it always retrieve the same titles from grace database.
Anybody can help me plz?
Thks in advance
Thks in advance
Make sure that you have auto-insert notification turned on for the drive. The easiest way to do that is by downloading Microsoft's TweakUI from their PowerToys collection (this is the XP version... I believe there are others).
Michael
i've noticed this problem as well (far back into SonicStage 2.#)
this is a method that seems to work all the time
1. While on the CD import screen take out the disc
2. Wait until the screen refreshes and says no disc inserted (may require a couple seconds)
3. Insert new CD
SS also has poor handling of multiple CDROM drives so if you plan on importing try and only have one CD in all of your drives. Normally SS tries to overlap the drives in the window (which doesnt make sense). Anyways best of luck
THanks all. The problem was that the autoplay windows xp option was damaged I have to edit the registry and put some values and erase several ones and now all works well.
I don't know if another problem that i have now is caused by this modifications but it's a topic for anotrher forum. My external USB HDD is making extrange sounds! and has errors, I don't know why!
Thanks
