adsdad Posted July 11, 2005 Report Share Posted July 11, 2005 I want to transfer data from harddisk to my MD 600. However, although I can see an entry for the 600 in ControlPanel/system/device manager, I cannot see it in Windows Explorer. According to page 59 of the user manual this operation is possible using just drag and drop. Using Windows 98SE. Any suggestions would be much appreciated. Quote Link to comment Share on other sites More sharing options...
Christopher Posted July 11, 2005 Report Share Posted July 11, 2005 Welcome to the forums. I would suggest you may want to try downloading and installing the Personal Audio Driver located in the Downloads section. Quote Link to comment Share on other sites More sharing options...
ROMBUSTERS Posted July 11, 2005 Report Share Posted July 11, 2005 like ive said before, i tried using my NH700 to back up data on my dads old PC (Windows 98SE) and it wouldnt recognize it at all. However once installing the PAD (personal audio driver) from CD, it found it right away. Quote Link to comment Share on other sites More sharing options...
adsdad Posted July 12, 2005 Author Report Share Posted July 12, 2005 Thanks for your reply. Tried that still the same. Getting more than a little frustrated! Quote Link to comment Share on other sites More sharing options...
dex Otaku Posted July 12, 2005 Report Share Posted July 12, 2005 I would check your system for:* third-party USB storage drivers* other devices plugged into the same USB controller [each controller usually has 2 ports]* drivers for other USB devices that might interfere* other background processes that might be interfering [process of elimination, unfortunately]Also, don't use the unit through a USB hub if you have one. Quote Link to comment Share on other sites More sharing options...
Killroy Posted July 12, 2005 Report Share Posted July 12, 2005 I want to transfer data from harddisk to my MD 600. However, although I can see an entry for the 600 in ControlPanel/system/device manager, I cannot see it in Windows Explorer. According to page 59 of the user manual this operation is possible using just drag and drop. Using Windows 98SE. Any suggestions would be much appreciated.←Hello,additionally, Windows will not show your MD-unit in any Explorer window as long as SonicStage or MD Simple Burner are running and accessing the device concurrently;Cheers - Killroy. Quote Link to comment Share on other sites More sharing options...
dex Otaku Posted July 12, 2005 Report Share Posted July 12, 2005 Hello,additionally, Windows will not show your MD-unit in any Explorer window as long as SonicStage or MD Simple Burner are running and accessing the device concurrently;Cheers - Killroy.←Hey - good point. [slaps forehead] Quote Link to comment Share on other sites More sharing options...
Killroy Posted July 12, 2005 Report Share Posted July 12, 2005 Hey - good point. [slaps forehead]←To be honest, I noticed this behaviour when I tried to "Export as WAV" a track with SonicStage. I wanted to store the WAV straight back to the disc I uploaded it from before, but the unit simply did not show up in the file selection list...Cheers - Killroy. Quote Link to comment Share on other sites More sharing options...
dex Otaku Posted July 12, 2005 Report Share Posted July 12, 2005 To be honest, I noticed this behaviour when I tried to "Export as WAV" a track with SonicStage. I wanted to store the WAV straight back to the disc I uploaded it from before, but the unit simply did not show up in the file selection list...I don't know when I noticed it [it would have been sometime during the first day I had my NH700], but as with many things it's become so ingrained that I don't think about it at all any more. Quote Link to comment Share on other sites More sharing options...
ROMBUSTERS Posted July 12, 2005 Report Share Posted July 12, 2005 Hey - good point. [slaps forehead]← haha wow we missed the ball on that one! Normally we deal with such technologically savvy things that the simple solution may have been the correct one! Quote Link to comment Share on other sites More sharing options...
