Pcm To Wav Sonicstage Converting
P Glew
Hi all,
I know that Linear PCM Hi-Md recorded audio is a digital format but SonicStage 3.1 will only convert analog recorded audio to WAV - will it work with PCM? Apparently PCM is recorded in analogue then digitized - does this mean I can transfer and covert to WAV the PCM recordings?
Thanks,
Phil
Welcome to the forum.
If you record via the Mic In, then Sonicstage will upload. If you record via the Digital In, then you will need to employ Marcnet's Hi-MD Renderer for conversion.
Thanks - that's made it all a lot clearer.
I was a registered user on here a few hours ago but tried to log-in and had to re-register. Also, the post I originally made has been deleted. Someone called "Volta" replied. It was about the same subject as this more or less.
Thanks,
Phil
