Error in Disabling LAN
Guest Stuge
"It is not possible to disable the connection at this time. This connection may be using one or more protocols that do not support plug-and-play or it may have been initiated by another user or the system account".
I can only disable it by going into the device manager, which is a several clicks hassle. When I try to re-enable it from a shortcut or from the Network Connections folder, the message "Connection Failed!" appears. And again, I have to go to Device Mgr to re-enable it.
PLEASE HELP ME.....
Using Windows xp (service pack 2)
I have searched on goolge but those tweaks didn`t help me at alll.
  • 3 weeks later...
