FLAC
ekb
OK, I thought I'd have to duplicate all my FLAC files to mp3s to move them to a NET MD.
Than I discovered that Nero supports FLAC, so I made a disk image, imported it into Simple Burn and copied it to the NZ10.
Unfortunately, a few of the songs had the music truncated ... not the files, the files are full length ... they just have no audio on the last third or so.
I backtracked and discovered the problem -- isn't it always -- is in the software. The songs are already screwed up when played in Simple Burn before they are transferred to the MD.
I'm not sure, but I think the same thing happened with a few mp3s I transferred with Real Player ....
Has anyone else had this problem ... could it be some kind of software conflict .... I'm using Simple Burn 1.0.03 with Soundstage 3.1.0.
Any other suggestions for putting FLACs on a NETMD without going analog?
Incidently, Sony, hypocrits that they are, have absolutely no problem with allowing NETMD owners to freely and fully copy any songs they want to their MDs as many times as they want ... they just won't let you do it free.
Spend 3 or 4 hundred dollars for Sony Sound Forge 7 or 8 or Sony Acid Pro5 and you'll find a handy "save to NETMD icon" right in the file menu -- it allows unrestricted file transfers.
Unfortunately, Sony has not seen fit to support FLAC in either product so that solution doesn't work for me -- though I have been a dedicated Sound Forge user since long before the Sony octopus swallowed it.
Does any one know if there is a NETMD plug-in for Adobe Audition (formerly CoolEdit Pro)? There is a FLAC plugin for Audition and it has a kickass batch function that would be perfect for exporting large numbers of files to an MD.
Thanks
