Rumz Posted July 28, 2005 Report Share Posted July 28, 2005 Being the audio whore that I am, when I had a problem with my original pair of Shure E3c I sent them in for repair/replacement and bought another pair to tide me over (can you say obsessive compulsive?) Anyhow, Shure didn't try to repair the other phones, they just sent me a a brand new E3c (which means it's sealed and has all the original package contents such as the different ear tips, etc, unused). Thought about giving them away as a gift but using the foam tips they're a little higher maintenance than some regular cans so I thought maybe I'd just sell these instead and use the money for some different cans.... just a thought. Quote Link to comment Share on other sites More sharing options...
sebastianbf Posted July 28, 2005 Report Share Posted July 28, 2005 How much for the earphones? Where can i check the specs? Quote Link to comment Share on other sites More sharing options...
Ishiyoshi Posted July 28, 2005 Report Share Posted July 28, 2005 How much for the earphones? Where can i check the specs?←--> further detailsE3c Technical Specifications:Speaker Type: Wideband MicroDriver Sensitivity (at 1kHz): 115dB SPL/mW Impedance (at 1kHz): 26 Ohm Cable Length: 1.57m (62 inches) Net Weight: 28g (0.9 oz) Input Connector: 3.5 mm (1/8") gold-plated stereo plug Quote Link to comment Share on other sites More sharing options...
