saldelmundo Posted August 19, 2005 Report Share Posted August 19, 2005 Using a MZ-RH910 I was making a recording that needs to be extremely accurate. I was using the manual levels settings, however when the device was accidentally turned off and back on before the recording, it reverted to the default setting which puts MIC AGC in "Standard" mode. On some high level parts of the recording, the limiter would kick in and reduce the input which may be helpful in some cases, but is exactly what I need NOT to happen in this instance.If anyone knows what ratio or DB the leves are reduced in this setting, and what limit it would kick in at, I would be eternally grateful! Link to comment Share on other sites More sharing options...
Ishiyoshi Posted August 19, 2005 Report Share Posted August 19, 2005 Using a MZ-RH910 I was making a recording that needs to be extremely accurate. I was using the manual levels settings, however when the device was accidentally turned off and back on before the recording, it reverted to the default setting which puts MIC AGC in "Standard" mode. On some high level parts of the recording, the limiter would kick in and reduce the input which may be helpful in some cases, but is exactly what I need NOT to happen in this instance.If anyone knows what ratio or DB the leves are reduced in this setting, and what limit it would kick in at, I would be eternally grateful!←Please do not double post. Link to comment Share on other sites More sharing options...
