SS 3.2 Woes (Reverted back to SS 3.1)
1kyle
Hi everyone
was thinking how good SS 3.2 was compared with SS 3.1 until I got a rude awakening.
I've got a library (huge approx 80GB - Mostly Classical Music ) I'd made using SS 3.1 -- all from CD's and should therefore be able to copy to MD.
Some of these CD's are quite old and the words "Copy Protection" hadn't even been heard of when these CD's were made.
Anyway trying to create some LP2 MD's (still use in the Car etc.) I get following error
Was trying to copy to an MZ-NH1 in MD mode.
Cannot convert the specified track.
SonicStage does not support the file format of the track
or the track is protected by copyright.
Bacchus et Araine, Danse d'Arinae -
Sonata in C major, Waldstein, 3rd movement -
Een vrouelic wesen; Missa L'Homme arme; Sanctus -
Piano Concerto No. 26 in D major; 1st movement -
Rhapsody in E flat major -
Romeo and Juliet; Romeo seul
Legendes; St. Francois d'Assise; La predication aux oiseaux -
Le rossignol des lilas -
Violin Concerto in D minor; 1st movement -
Don Giovanni; Gia la mensa e preparata -
The Magic Flute; Der Bogelfanger bin ich ja -
O Solitude -
The Fairy Queen; Chaconne -
Elijah; Aber der Herr sieht es nicht -
I though OK I'll be clever --deleted the library and restored from the backup.
Still the same error.
Uninstalled SS 3.2 -- re-installed SS 3.1 everything Worked thank goodness.
So any ideas on what's going on.
On another machine I tried a small test with SS 3.2 -- Copied a CD to the library using Atrac3+ @256kbs (I usually use that in my Library as it's fine most purposes)
It would copy to MD without problems.
Cheers
-K
Edited by 1kyle
[solved --
Deleted Entire Library (Not the Backup)
Uninstalled SS 3.1
Re-installed SS 3.1 again
Upgraded to SS 3.2
Restored the library.
Not sure why the original problem occurred --anyway it's working now.
Cheers
-K
