tanktop Posted September 2, 2005 Report Share Posted September 2, 2005 (edited) Hi all,I am having problems getting sonicstage 3.1 or 3.2 to run. It installs without any problems (i disable all non essential services prior to install).When I start it up for the first time it it goes to update the database and then bombs out with no error messages.Also if i run the conversion tool i get the error message "Cannot optimize the database because the database file version is not recent enough".Any help would be greatly appreciated as at the moment I cannot use my nw-hd5 thanks in advancebtw am running windows xp pro and fully uptodate on the patches. Edited September 2, 2005 by tanktop Quote Link to comment Share on other sites More sharing options...
Christopher Posted September 2, 2005 Report Share Posted September 2, 2005 Welcome. Download the MDAC repair utility from the Downloads section and fix both JET and MDAC. Quote Link to comment Share on other sites More sharing options...
tanktop Posted September 6, 2005 Author Report Share Posted September 6, 2005 Hi,I did that initially with no joy, but have since run the MDAC and Jet repair again and it resolved the problem.Once it is working is not a bad piece of software.Cheers Quote Link to comment Share on other sites More sharing options...
