Gangstah Posted September 22, 2005 Report Share Posted September 22, 2005 hi guys,i was wondering, what is the equivalent in sound on a hi-md atrac plus format when compared to lp2 on netmds...also will atrac plus be more compressed yet sound better? also how much music would on a hi-md if all songs were to be encoded at around 160-190kbps..thanks Quote Link to comment Share on other sites More sharing options...
LupinIV Posted September 22, 2005 Report Share Posted September 22, 2005 hi guys,i was wondering, what is the equivalent in sound on a hi-md atrac plus format when compared to lp2 on netmds...also will atrac plus be more compressed yet sound better? also how much music would on a hi-md if all songs were to be encoded at around 160-190kbps..thanksHey Gangstah,do a little search in the Technical forum. Also there is the new Atrac Network. There is a lot more to find in the forum if you look around....Cheers Quote Link to comment Share on other sites More sharing options...
Qwakrz Posted September 23, 2005 Report Share Posted September 23, 2005 There is not much that is the same as LP2, except for Hi-SP but thats the same as SP to my ears.If however you use SS to transfer all your music just keep using LP2 as it still workes with Hi-MD formatted discs but only when transfering over USB to the Hi-MD. Quote Link to comment Share on other sites More sharing options...
