cannot transfer
zmelkoow
i was using sonic stage for editing song that i have recorded.. then my computer shut down and i had to replace all my softwear including my sonic stage... now i have installed a new version of sonic stage and the tracks that i had edited earlyer cannot be transfered from md to computer... what to do? what to do? -_-
i could really use some help...
The general consensus is that if you have editd on your unit you will have difficulty, and is you have edited and transferred you will have more.
Your best bet may be to download in realtime maybe using Marc's renderer.
Good luck,
Bob
You can use Audacity (available in the download section) to import the tracks to your computer.
First you have to connect the himd to the pc with the usb cable. Then start SonicStage and Audacity. Start recording with Audacity. This program will record all the sounds in your computer (it's like having a fake sound card, so turn off all windows sounds etc, etc.) Now, play the songs recorded in your minidisc using SonicStage and Audacity will record them in a file.
Then you will have a track made by audacity and you can edit it in a program like Cool edit pro or other audio editing software to cut tracks, etc. Then just import the files into Sonicstage and transfer them to your minidisc.
Edited by sebastianbf
