gman_g Posted September 26, 2005 Report Share Posted September 26, 2005 Does anyone use the MD Lense Cleaner and Recording Head Cleaner? I'm have several (MD & Hi-Md) units and I'm wondering if this is a good practice to follow or is it really not advisable.Thanks for your help! Quote Link to comment Share on other sites More sharing options...
sebastianbf Posted September 26, 2005 Report Share Posted September 26, 2005 I have one cleaning disc and I use it once every four months. I think that it's not so good to use this kind of cleaners because the brush may scratch the lens, but I have never had a problem with it. Quote Link to comment Share on other sites More sharing options...
MDGB2 Posted September 26, 2005 Report Share Posted September 26, 2005 (edited) Clean it when it needs it. I.e. if you start to hear pops or clicks. Edited September 26, 2005 by MDGB2 Quote Link to comment Share on other sites More sharing options...
Alexx Posted September 26, 2005 Report Share Posted September 26, 2005 how do you clean it?do you just put a brush into the player? Quote Link to comment Share on other sites More sharing options...
MDGB2 Posted September 26, 2005 Report Share Posted September 26, 2005 You can get lense/head cleaning MDs. Quote Link to comment Share on other sites More sharing options...
Alexx Posted September 26, 2005 Report Share Posted September 26, 2005 doesn't that just do the same as a eyeshadow brush though: or an air blaster Quote Link to comment Share on other sites More sharing options...
MDGB2 Posted September 27, 2005 Report Share Posted September 27, 2005 Suppose so, but less chance of damaging the unit. Quote Link to comment Share on other sites More sharing options...
