Transfer Hi-MD Folder from HD drive back to MD
FalconX
Hello,
I have bought the MZ-RH10 for some days and I am using SonicStage v3.2.
I recorded something with Line-In, I started transfering the tracks with SonicStage...I didn't finished the transfer.
And I was a little bit confused about the title names (actually I wanted just one file with my recording), the tracks didn't seem to be in the right order and I was a little bit in a hurry, because I needed the MD for another recording (I only bought one Hi-MD disc)...so I thought, when I have more time I will rename the titles on the Hi-MD and begin the transfer later again, the easiest way I thought is to copy the Hi-MD folder directly to my harddrive and maybe import the MD from C: in SonicStage - but no option for import from local drives in SonicStage. So, I copied the whole HMDHIFI folder back to minidisc - but SonicStage didn't recognize any titles on the MD like before. What should I do?
Question 1: How to import Minidisc (hma files) from local drives in SonicStage (or other software)?
or
Question 2: How to repair the Toc of a MiniDisc to make the minidisc with audio layout recognizable in SonicStage?
You may be out of luck with this one... I think you just lost what was on your disc.
There is no known way to copy those files back to the HiMD and transfer, or even play the audio...
May be worth holding onto the files though, just in case something comes around in the near future that can decode those for you.
