BalancedScience Posted September 30, 2005 Report Share Posted September 30, 2005 Im wondering if it is possible for the himd disc or standard discs be used to lock a computer or laptop like them usb key locks you can buy?Anyways Peace Quote Link to comment Share on other sites More sharing options...
raintheory Posted September 30, 2005 Report Share Posted September 30, 2005 (edited) Thats a good question.Seems like you should be able to do this, as the HiMD is recognized as a removeable media drive.Might be as simple as copying some drivers/files and an autorun.inf file onto your HiMD disc.Search around for PC Lock USB software, and try it out. I don't have my USB cable here at work or I would try it out. Edited September 30, 2005 by raintheory Quote Link to comment Share on other sites More sharing options...
Ishiyoshi Posted September 30, 2005 Report Share Posted September 30, 2005 BalancedScience said: Im wondering if it is possible for the himd disc or standard discs be used to lock a computer or laptop like them usb key locks you can buy?This net article "New software, new learning opportunity for PC Security Wireless USB PC Lock" provides some good information. Quote Link to comment Share on other sites More sharing options...
