Guest Stuge Posted December 14, 2005 Report Share Posted December 14, 2005 Like to see your "Walkman" in this State.....I don`t think so but look at the pictures below ..MZ_NH600serman__sm_sd_.pdf Just take out two screws from your NW-E500/400/A600(series ) & thats it Source:".Sonymatome" site Quote Link to comment Share on other sites More sharing options...
0 sylikc Posted December 14, 2005 Report Share Posted December 14, 2005 Like to see your "Walkman" in this State.....I don`t think so but look at the pictures below ..MZ_NH600serman__sm_sd_.pdf Just take out two screws from your NW-E500/400/A600(series ) & thats it Source:".Sonymatome" site←Ouch. I hope you didn't do that to your own player... if so, does it work if you put the two screws back in? Btw, it's not clear from the pictures, but is that Li-on battery removable? I've love to go power another device with a 50 hour battery Quote Link to comment Share on other sites More sharing options...
0 icefire2hot Posted December 15, 2005 Report Share Posted December 15, 2005 A6XX mount the same µprocessor CXR704060, so should have the same audio performance as EXX series, or may be sony made minor modify ( such as USB2.0 )then only updated the version code. we didn't know the detail info. Quote Link to comment Share on other sites More sharing options...
0 Guest Stuge Posted December 15, 2005 Report Share Posted December 15, 2005 Ouch. I hope you didn't do that to your own player... if so, does it work if you put the two screws back in? Btw, it's not clear from the pictures, but is that Li-on battery removable? I've love to go power another device with a 50 hour battery ←I have already opened my player(E505) just to see the Li-Ion battery but after putting the screws back ...Everything worked fine again But it left some scratches inside the lid ..)Yes ,It is Li-on battery Quote Link to comment Share on other sites More sharing options...
Guest Stuge
3 answers to this question
