Themib Posted December 15, 2005 Report Share Posted December 15, 2005 After a very frustrating night with Connect trying to load songs to the NW1000, I decided to try SS3.3It recognises the device, but wont transfer songs to it, it saya hard disk full.None of cof connect is running in the background.The NW has the firmware update and was formated in connect.Its properties are listed as 0 free, 0 used!!!Can anyone think of a reason why I cannot use ss3.3 and my nw1000?Thanks.Strangely, this morning.I closed down all ss background tasks, moved the usb from the hub to the pc direct, allowed the transfer to convert all tracks and connect worked fine, no errors or lockups. Quote Link to comment Share on other sites More sharing options...
Guest Stuge Posted December 15, 2005 Report Share Posted December 15, 2005 I closed down all ss background tasks, moved the usb from the hub to the pc direct, allowed the transfer to convert all tracks and connect worked fine, no errors or lockups.Remember Sony never recommends to Use Usb hub..So connect your player directly to your ComputerPlease Read "FAQs & Knowledge" for A1000 here:FAQs & Knowledge(A1000)Sonic Stage Query First format your player (through Mani menu)then try tom Sonic Stage Quote Link to comment Share on other sites More sharing options...
Themib Posted December 15, 2005 Author Report Share Posted December 15, 2005 .Remember Sony never recommends to Use Usb hub..So connect your player directly to your ComputerPlease Read "FAQs & Knowledge" for A1000 here:FAQs & Knowledge(A1000)Sonic Stage Query First format your player (through Mani menu)then try tom Sonic Stage←Format with connect? or SS?Thanks. Mark Quote Link to comment Share on other sites More sharing options...
